някой знае ли как точно се ползва това устройство и за какво е това копче?
Колата е T25 2.0 VVTi.
Initial pairing
Note: Use this procedure only if there are no handsets paired to the system.
Seated in the car and ignition turned on:
1 Press the talk button.
2 When prompted, say “Pair phone”.
The system responds: Set your phone in scan mode and enter 1234 when prompted
for the passcode.
3 When the phone displays the device name, select the device.
The phone displays the passcode entry screen.
4 Enter the passkey (1234).
The phone displays “Pin verified,” and the system says: Pairing complete. Connection in
progress.
Note: Some phones ask you to accept the Bluetooth® link. Enter yes.
Upon successful completion, the system says: Connection is complete. Phone <n> ready
for use
Additional pairing
To pair additional handsets to the system, seated in the car and ignition turned on.
2 When prompted, say “Setup menu”.
The system responds: Setup menu. Please say a command.
3 Say “Pair phone”.
for the passcode.
4 When the phone displays the device name, select the device.
5 Enter the passkey (1234).
The phone confirms that the pin is verified and says: Pairing complete. Connection in
progress.
for use.
Selecting a phone
3 Say “Connect phone <n>”.
The system responds: Connecting phone <n>.
Upon successful completion, the system says: Connection complete.
С малко четене на http://www.toyota-tech.eu/Aim/Aim.aspx?pubtype=AOM ще се справите.List phones paired to the system
3 Say “List phones”.
The system says: The following phones have been paired: phone 1, etc
