http://www.densoiridium.com/howtoreadusedplugs.phpJapanese_fever написа:защо са толко черни свещите...?
prichini za tozi kod za tazi kola biha bili:lederman написа:P1300 Igniteir Circuit Malfunction
http://alflash.com.ua/P1300.htm
може да е причина за черните свещи...
и със сигурност е причина ECU-то да не вижда искрите.
"The ECM determines ignition timing and outputs the ignition signals (IGT) for each cylinder. Based on IGT signals, the igniter controls the primary ignition signals (IGC) for all ignition coils. At the same time, the igniter also sends an ignition confirmation signal (IGF) as a fail-safe measure to the ECM."
ето и един интересен наръчник за запалителната система на Toyota:
http://www.autoshop101.com/forms/h23.pdf
prichini za P0125 za tazi kola(direkno izvadeno ot Repair Manual-a za 97 Lexus ES300):lederman написа:за P0125
http://www.obd-codes.com/p0125
This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine.
бавно е загрял (щом е работил на място).
A code P0125 may mean that one or more of the following has happened:
Insufficient warm up time
Low engine coolant level
Leaking or stuck open thermostat
Faulty coolant temperature sensor
Потребители разглеждащи този форум: Bing [Bot], Google [Bot] и 4 госта
