когато застудя -4, -9 C когато пусна парното се чува едно скърцане, или виене особено на по-високи обороти, трудно ми е да определя точно звука. Дали ако сваля моторчето с перката на парното и ги смажа би помогнало и евентуално как бих могъл да го направя?
Благодаря предварително.
Corolla Verso Проблем с парното (скърца)
- marin.stratev
- Регистриран на: 27 Яну 2015 20:09
- Местоположение: Смолян
- Akima
- Автомобил: Altezza
- Благодарил/а: 155 пъти
- Получена благодарност: 266 пъти
Re: Corolla Verso Проблем с парното (скърца)
Една тема под теб - http://toyotabg.eu/viewtopic.php?f=29&t=28685.
Още:
http://www.toyotabg.eu/viewtopic.php?f=29&t=24554
http://toyotabg.eu/viewtopic.php?f=2&t=18012
http://www.yotatech.com/f2/front-heat-p ... ndex2.html
Още:
I say might because the problem was only there in the summer in humid conditions. Going through the process helped me to see why this is was the case.
1) I removed the glove compartment
1.1 Remove passenger side trim from the runner of the door
1.2 Remove the trim under the glove compartment (there's a plastic nut that can be turned by hand)
1.3 Remove the two lower nuts and the three upper screws. As they start to come out you'll want to support the glove compartment.
1.4 Pull the glove compartment straight out.
2) Remove blower motor from housing (The haynes manual has a good picture of this in its section called "Blower unit - check removal and installation"
2.1 Disconnect electrical connector from motor (squeeze clip together close to the motor)
2.2 There are three brass colored screws with hex heads that can also take a flathead screwdriver or a Torx (spelling?) type screwdriver. Support the blower fan and back all three out. The fan and motor can now be lowered straight down.
2.3 There's a cover that will pop off on what was the screw hole that was closest to the driver's side of the car. Pop it off
2.4 With the assembly in its upright position shoot some WD 40 into the motor housing towards the base where the axis of the motor would be and work it in a little
3) Close it all back up and reassemble everything.
What I came to realise though was that this small access cover could have been reached without taking out the glove compartment or the blower unit.
The easy way
Look up under / behind your glove compartment. The round black plastic part closest to the door is the blower unit. On the bottom there are only 3 screws that have a hex head. The heads also take flathead screw drivers or torx screwdrivers.
Remove the one that is closest to the center of the car.
You should be able to get your finger under the cover at the edge to pop it off.
Spray a little WD 40 through the straw towards the base of the blower unit. You're trying to lubricate the lower axis of the motor.
Snap the cover in place and screw it down.
That's it.
- marin.stratev
Благодаря,
само да се стопли времето и залягам да го направя, че ме подлудява.
