Съкращения, използвани в автомобилната литература
sluchaen_fen
Мнение от sluchaen_fen » 16 Яну 2007 00:57
4WD = Four Wheel Drive
4WS = Four Wheel Steering
ABC = Active Body Control
ABS = Anti Blokier System
AC = Air Condition
ACC = Active Cruise Control
ACC = Automatic Climate Control
AGS = Adaptive Gearbox Shift
ALB = Anti Lock Braking
AMG = Aufrecht Melcher Grossaspach
ASC = Automatic Stability Control
ASC+T = Automatic Stability and Traction Control
ASMS = Automatic Stability Management System
ASR = Anti Schlupf Regelung
ATM = Adaptive Transmission Management
ATV = All Terrain Vehicle
AUC = Automatische Umluft Control
AWD = All Wheel Drive
BAS = Brake Assystant System
BST = Battery Safety Terminal
CAN = Controller Area Network
CC = Cruise Control
CDI = Capacitor Discharge Ignition
CDI = Common-rail Diesel Injection
CFI = Central Fuel Injection
CL = Comfort Luxe
CNG = Compressed Natural Gas
CUV = Cross-over Utility Vehicle
CVT = Continously Variable Transmission
DBC = Dynamic Brake Control
dCi = diesel Commonrail injection (Renault)
DDE = Digital Diesel Electronics
DISA = Differenzierte Sauganlage sistem
DOHC = Double Over Head Camshaft
DME = Digital Motor Electronics
DSA = Dynamic Stability Assistance
DSC = Dynamic Stability Control
DSTC = Dynamic Stability & Traction Control
dTi = dizel Turbo intercooler
DTI = Dizel Turbo Intercooler
EBD = Electronic Brakeforce Distribution
EBV = Elektronische Bremskraft Verteilung
ECU = Engine Control Unit
EDC = Electronic Damper Control
EDC = Electronic Diesel Control
EDS = Elektronische Differencialsperre
EFI = Electronic Fuel Injection
EG = European Gas
EGR = Exhaust Gas
EMC = ElectroMagnetic Compatibility
EPS = Electronic Power Steering
ESP = Electronic Stability Program
ETC = Electronic Traction Control
ETS = Electronic Tracion System
EV = Electric Vehicle
FDR = Fahr Dynamik Regelung
FFV = Flexible Fuel Vehicle
FIRE = Fully Integrated Robotized Engine
F.I.R.S.T. = Fully Integrated Road Safety Technology
FPS = Fire Protecting System
GDI = Gasoline Direct Injection (Mitsubishi)
GL = Grand Luxe
GPS = Global Positioning System
GT = Gran Touring/Tourismo
GTI = Grand Tourismo Injection
GTP = Grand Touring Prototype
GTR = Grand Turismo Racing
HDC = Hill Descent Control
HDI = High Density Injection
HDi = High-pressure Direct Injection
HP = Horse Power
HPi = High-power injection
JTD = uniJet Turbo Diesel
i, I = Injection
IC = Inflatable Curtain
ICIM = Individual Control Intake Mainfold
IMS = Instant Mobility System
IRD = Intermediate Reduction Drive
ISOFIX = International Standard Organization FIX
ITS = Inflatable Tubular Structure
KW = Kilowatt
LPG = Liquefied Petroleum Gas
LSD = Limited Slip Differential
MPI = Multi Point Injection
NGV = Natural Gas Vehicle
OBD = On Board Diagnostic
OHV = Over Head Valve
PDC = Park Distance Control
PES = Poli Elipsoid System
PPD = Passenger Presence Detection
PRS = Programmed Restraint System
SIPS = Side Impact Protection System
SDI = Standard Diesel Injection
SMH = Societe de Microelectronique et d'Horlogerie
SOHC = Single Over HeadCamshaft
SPI = Single Point Injection
SRS = Supplemental Restraint System
STC = Stability & Traction Control
SUV = Sport Utility Vehicle
TC = Traction Control
TCS = Traction Control System
TD = Turbo Diesel
TDI = Turbo Diesel Intercooler
TDI = Turbo Diesel Injection
TRC = Traction Control
VANOS = Variable Nockenwelle Steuerung
VDC = Vehicle Dynamic Control
VIN = Vehicle Identification Number
VIS = Variable Induction System
VTEC = Variable valve Timing and lift Electronic Control system
VVT-i = Variable Valve Timing - intelligent
WHIPS = WHiplash Protection System
WET W = Engineered Tread
sluchaen_fen
Задвижване на колелата:
Мнение от sluchaen_fen » 16 Яну 2007 01:04
FWD = Front Wheel Drive (предно предаване)
RWD = Rear Wheel Drive (задно предаване)
АWD = All Wheel Drive (постоянно зацепено интегрално предаване 4x4)
4WD = Four Wheel Drive (четири задвижващи колела)
(All-Track = AWD)
Примери за други използвани съкращения и обозначения:
4x4 при много марки
Quattro при Audi
X при BMW (например BMW525 iX или BMW X5)
4 Matic при Mercedes-Benz
Allrad при Mitsubishi
Synсro при Volkswagen (І, ІІ и ІІІ)
4 Motion при Volkswagen (ІV, V и VІ)
Quadra при Renault
Потребители разглеждащи този форум: Amazon [Bot], Google [Bot] и 1 гост
