MOLBA - kam otlichno angliisko govoriashtite - za prevod...
Дон Хуан
Регистриран на: 23 Апр 2008 10:59
Местоположение: Кипър
Мнение от Дон Хуан » 23 Окт 2008 11:21
Privet na fenovete
Namerih edna statiika kak migachite na Celica 6 gen predi feisa da se napraviat kristalni ili po tochno "clear"...zashtoto ne se prouizvejdat takiva za modelite '94-'96 god.
Mnogo bih jelala da gi napravia i moite takiva no kato cheta statiata neshto se omotvam i nemoga da razbera kak tochno se pravi trika?! wacko.gif
MOLBATA mi e niakoi da go prevede tochno i da go napishe za da moejem da go polzvame.... :help:
eto i teksta:
Approximate Time: 2 Hours + Drying Time
Required Tools: Clear office lighting material
Silicone caulk
Strong glue (epoxy resin works)
Jigsaw
Bench grinder (sand paper will work)
Heat gun or hairdryer
Drill and small drill bit
Start by removing your stock turn signals from your bumper by removing the screw that holds it in. Once off the car, heat the glue on the edges of the amber lens until it is very very soft and you can pull the amber lens off. Be patient and careful, and don't melt your amber lense. This step can take a while.
Use the old lens as a pattern to trace onto the clear office lighting material, but make the pattern a little bigger than it needs to be, because you don't want it to be too small. You can always sand it down later. Next, cut out the pattern by using the jigsaw.
Now, using the grinder or sandpaper, sand it until it sits perfectly on your signal housing. You can carefully drill a hole in the lens where the retaining screw will come through, or you can screw the completed assembly in from the back of the bumper using something like a wing-nut-headed screw.
At this point you may want to paint the inside of the light housing with silver or chrome paint, so that it reflects light better, but even if you don't, your turn signals will still look fine.
Using the strong glue you chose, put a consistent bead of it between the new lens and the housing. Clamp the two pieces together and allow them to dry overnight.
Before putting them on your car, seal all the edges with the silicone caulk, because you don't want any water in the housing. When you're done, simply install the turn signals back in your car and enjoy!
Blagodaria predvaritelno :thumbsup:
CHEERS
Scott
Местоположение: Bristol, UK
Re: MOLBA - kam otlichno angliisko govoriashtite - za prevod
Мнение от Scott » 23 Окт 2008 13:12
Дон Хуан написа:MOLBATA mi e niakoi da go prevede tochno i da go napishe za da moejem da go polzvame....
Не гарантирам точен превод, защото може да съм позабравил някои понятия или те са били променени междувременно
Приблизително време за изработка: 2 часа + време за съхнене
Необходими инструменти и материали: Прозрачен плексиглас (подобен на използвания в осветителни тела за да издържа на температурата), силикон, здраво лепило (епоксидна смола става), моделно лъкче(трионче) за изрязване, едно време режехме плексиглас с конец, шмиргел (шкурка би свършила работа), пистолет с топъл въздух или сушоар, дрелка и малки свредла
Започнете с махане на фабричните мигачи от бронята, отвивайки винтовете, дето ги държат. След като ги свалите, нагрейте лепилото по ръбовете на жълтите 'стъкла' докато 'омекне' и разделете основата и 'стъклото'. Бъдете внимателни и търпеливи, за да не стопите жълтото оригинално стъкло (очевидно в случай че не се получи желания ефект да можете да си възстановите оригиналния вид).
Използвайки старото стъкло като модел, очертайте малко по-широки контури върху прозрачния плексиглас. В последствие може да го изшкурите, ако е по-голямо. След това изрежете контура с триончето (лъкчето).
Сега с шмиргела или шкурка, го оформете, докато прилегне плътно върху основата на мигача. Внимателно пробийте отвори, където са винтовете за захващане, или може да захванете целия мигач от отзад към бронята с подходящ винт с крилчата гайка.
Сега, може ако желаете да боядисате вътрешната част на основата на мигача със сребърна или хромна боя за по-добро рефлектиране, но дори да не го направите, пак ще изглежда добре.
Сега с лепипото, което имате 'изцъркайте' равномерен слой с достатъчно количество по периферията на основата и новото 'стъкло'. Захванете плътно притиснати двете части и ги оставете да изсъхнат през нощта (зависи от лепилото и колко е времето му за изсъхване).
Преди да ги сложите на колата уплътнете със силикон по ръбовете, за да не влиза вода вътре в мигача. Когато сте готови, монтирайте мигачите и се кефете.
Дон Хуан
10x
Мнение от Дон Хуан » 23 Окт 2008 16:46
Mnogo Blagodaria na kolegata Scott :thumbsup:
Ima edni fenove ot UK gi prodavat tochno takiva no tsenata e 230 leva za komplekt koeto mi se struva dosta sad.gif
Mislia da se probvam niakoi den.....
CHEERS :thumbsup:
