British Touring Car Championship Carina Specs
El Camino
Мнение от El Camino » 12 Дек 2004 23:52
Toyota Carina E Specification
ENGINE
Designation: 3S-GE
Type: Water-cooled, in-line, 4-cylinder,
16-valve, DOHC
Bore & stroke: 86mm x 86mm
Total displacement: 1998cc
Engine management Zytek multipoint, sequential and
system: programmable fuel injection
Power output: Around 300bhp @ 8500rpm
Maximum torque: 220 lb/ft
Lubrication system: Dry-sump with oil reservoir located
in engine bay; Mobil 1 lubricant
BODY & CHASSIS
Dimensions: Height : 1410mm
Length : 4530mm
Width : 1695mm
Wheelbase : 2580mm
Track - front/rear: 1455mm
Kerb weight: 975kg
Fuel capacity: 60 Litres
Transmissions: Xtrac sequential box, six forward
speeds and reverse; quick change dog-
engagement gears
Clutch: AP racing clutch, hydraulic operation
Suspension: Toyota Super Strut front, MacPherson
strut rear, coil springs, heavy-duty
hubs
Brakes: Brembo racing callipers with 14"
ventilated discs; Mobil brake fluid
Tyres & wheels: OZ magnesium-alloy racing wheels, 18"
or 19" diameter with Michelin 210/650
racing tyres
Instrumentation: Toyota Measurement System (TMS) data-
logging computer with programmable data
display
Press Release issued to "Racing Into the Future"
Courtesy Paul Risbridger, Toyota Team GB Team Manager
Towa e specifikaciqta na British Touring Car Championship Toyota Carina E. Interesnoto e, che dwigatelite qwno ne sa turbinirani (sled kato sa GE?). Kakwo predpolagate e dowelo na 300 konq?
jamie
Местоположение: U S A
Мнение от jamie » 13 Дек 2004 10:17
От това може смело да си извадиш изводите че е с валове, вероятно 300 градусови (понеже си е пистарка), степен на компресия поне 11.5 и балансирани и олекотени елементи по мотора. Въртящия момент определено не е на нивото на турбо-моторите 2.0 Тойота.
Потребители разглеждащи този форум: Vilich и 5 госта
