Moje li ne6to prednoto gurne ili nqkoiq traba da e zdala bagaja?
Ili kakvo moje da e?
Edin priqtel e cepnal prednoto si garne i mislq, 4e pri nego se use6ta podoben miris.
Sulfur is another contaminant. It is found in small amounts in gasoline. As long as the concentration is limited, it causes no problem. But too much sulfur in a batch of bad gasoline can create a rotten egg odor in the exhaust and cause the converter to light off at a higher than normal temperature, increasing pollution and possibly damaging the converter.
Mersi ALTEZZA.ALTEZZA написа: Sulfur is another contaminant. It is found in small amounts in gasoline. As long as the concentration is limited, it causes no problem. But too much sulfur in a batch of bad gasoline can create a rotten egg odor in the exhaust and cause the converter to light off at a higher than normal temperature, increasing pollution and possibly damaging the converter.
Ne sum hapval ot Velikden! biggrin.gifbad_dog написа:Japanese,
признай си, че си похапнал яйца и си търсиш извинение
Потребители разглеждащи този форум: ccvetan и 3 госта
