Скоростомерът Ви показва ли завишена скорост, сравнен с GPS?
Raya
Автомобил: Бързи крачета
Мнение от Raya » 28 Сеп 2011 23:36
Аз на извънградкото винаги съм с GPS за да виждам реално с колко нарушавам и още колко може (spored sostoianieto na portmoneto).
Чо :)
Регистриран на: 11 Юни 2011 18:57
Местоположение: София, Ямбол
Автомобил: Prius 4
Мнение от Чо :) » 28 Сеп 2011 23:41
Vesko написа:dori i edin satelit e dostatachen za da opredelish skorostta po dopler efekta. Vse pak radarite go praviat samo po edin reshavat za skorostta:)
Един, ако се движиш в посока срещу него (приближаваш/отдалечаваш).
П.П.
Smile is Health rolleyes.gif Keep Smiling ... :D Усмихни се ... Животът е Хубав :thumbsup:
grunge_is_dead
Регистриран на: 20 Ное 2008 22:20
Местоположение: Стара Загора/София
Мнение от grunge_is_dead » 29 Сеп 2011 10:01
Един цитат от United Nations Economic Commission for Europe (UNECE).
http://www.unece.org/
International agreements
In many countries the legislated error in speedometer readings is ultimately governed by the United Nations Economic Commission for Europe (UNECE) Regulation 39[3] which covers those aspects of vehicle type approval which relate to speedometers. The main purpose of the UNECE regulations is to facilitate trade in motor vehicles by agreeing uniform type approval standards rather than requiring a vehicle model to undergo different approval processes in each country in which it is to be sold.
European Union member states must also grant type approval to vehicles meeting similar EU standards. The ones covering speedometers [4] [5][6] are similar to the UNECE regulation in that they specify that:
The indicated speed must never be less than the actual speed, i.e. it should not be possible to inadvertently speed because of an incorrect speedometer reading.
The indicated speed must not be more than 110 percent of the true speed plus 4 km/h at specified test speeds. For example, at 80 km/h, the indicated speed must be no more than 92 km/h.
The standards specify both the limits on accuracy and many of the details of how it should be measured during the approvals process, for example that the test measurements should be made (for most vehicles) at 40, 80 and 120 km/h, and at a particular ambient temperature. There are slight differences between the different standards, for example in the minimum accuracy of the equipment measuring the true speed of the vehicle.
The UNECE regulation relaxes the requirements for vehicles mass produced following type approval. At Conformity of Production Audits the upper limit on indicated speed is increased to 110 percent plus 6 km/h for cars, buses, trucks and similar vehicles, and 110 percent plus 8 km/h for two or three wheeled vehicles which have a maximum speed above 50 km/h (or a cylinder capacity, if powered by a heat engine, of more than 50 cc). European Union Directive 2000/7/EC, which relates to two and three wheeled vehicles, provides similar slightly relaxed limits in production.
Is there another reason for your stain ?
danny
Регистриран на: 21 Мар 2011 15:22
Мнение от danny » 14 Окт 2011 15:19
Чо :)
Автомобил: Prius 4
OFF topic
Мнение от Чо :) » 14 Окт 2011 16:23
Голям луксозен джип минава през забутано селце, завива със замах по потънала в кал уличка и пропада в дерето.
Две баби го наблюдават:
- Глей, Гицке, още един с жипиес....
steel1978
Регистриран на: 10 Фев 2010 04:04
Мнение от steel1978 » 15 Окт 2011 00:49
Аз на моя авенсис съм си правил експеримент - карам по магистралата със 140 на круиз точно и нулирам средната скорост в движение,борд компютъра ми показва ,че карам със 132 и не мърда ако ще и 20 км да мина с тази скорост..
Georgepetrov137
Мнение от Georgepetrov137 » 15 Окт 2011 14:20
Мисля, че целият този спор е излишен - GPS навигацията никога не отчита точно нито разстоянието, нито моментната скорост.
Vesko
ЗАВИНАГИ С НАС.....
Мнение от Vesko » 15 Окт 2011 20:03
Georgepetrov137 написа:Мисля, че целият този спор е излишен - GPS навигацията никога не отчита точно нито разстоянието, нито моментната скорост.
Нито дори координатите.... Чак е чудно как амерканските бомби уцелват целите си в градски условия biggrin.gif
Те вярно че ползват другият канал на ГПС-а... ама то отрозените сигнали надали само на "гражданският" канал се отразяват smile.gif
New Bitmap Image (3).jpg (63.32 KiB) Преглеждано 2506 пъти
Благодарил/а: 525 пъти
Мнение от slowtraveler » 15 Окт 2011 22:34
Всичко е относително. Зависи какво разбираш под 'точно'...
GPS също има определена точност, както всеки измервателен уред.
Но спора наистина е излишен - скоростомера е в пъти по-неточен (включително принудително внесената грешка) от GPS...
Vesko
ЗАВИНАГИ С НАС.....
Мнение от Vesko » 16 Окт 2011 00:19
slowtraveler написа:
Мнение от slowtraveler » 16 Окт 2011 08:16
Имах предвид принудителната грешка на скоростомера, която не е махната :thumbsup:
