Ама нещо липсва една тема тук...?
КЕФ ЦЕНА НЯМА
2.Toyota Previa-156ps-LHD
4.Mazda RX7 FD-500ps-RHD
5.Subaru Justy 68ps-LHD
- Georgimitrovich
- Регистриран на: 08 Апр 2008 00:59
b_d
b_d
Subaru Impreza STi V4
GC8
Инфо за двигателя:
Type - D Type STi
Engine type - EJ20K
Capacity (ps/rpm) - 280/6500
Torque (kg * m/rpm) - 36.0/5000
Displacement (cc) - 1994
Bore X stroke (mm) - 92x75
Compression ratio - 8
Cylinder block structure - Open deck
Valve clearance adjustment method - Inner shim
Ignition system - Simultaneous ignition
Piston - Forging
TURBO part number - 14412AA220 E9709-E9808
Type - RHF5HB
Boost pressure (mmHg) - 800 (15.5psi, 1,05bar)
Ето малко инфо за скоростите:
Transmission code - TY752VBCAA
1st Gear - 3.166
2nd Gear - 1.882
3rd Gear - 1.296
4th Gear - 0.972
5th Gear - 0.738
FINAL - 4.444
Diff Code - D,E
Diff Code - D
Diff Front - Open
Diff Rear - Screw refuse type LSD - 27011AA280
Center Diff - Screw refuse type LSD
Wheel Size - 205/50/16 7J
Diff Code - E
Diff Front - Open
Diff Rear - Sure truck mounted LSD
Рапорт Даден!
GC8
Инфо за двигателя:
Type - D Type STi
Engine type - EJ20K
Piston - Forging
Type - RHF5HB
1st Gear - 3.166
2nd Gear - 1.882
3rd Gear - 1.296
4th Gear - 0.972
5th Gear - 0.738
FINAL - 4.444
Diff Code - D,E
Diff Code - D
Diff Front - Open
Diff Code - E
Diff Front - Open
Рапорт Даден!
- Japanese_fever
agent dust
- Japanese_fever
Shto, STi-kata da ne bi da q gotvqt za race track?!?V35GTR написа: ... I samo 1-vi mesta!!!!
Koq godina e?
btw, tova JDM Impreza li e?
p.s.
mag kato tvoqta li e?
- Nai-krasivata WRX(model '99) za men :-)
- 99–WRX.jpg (45.01 KiB) Преглеждано 5104 пъти
