Ъпдейт на медия
Ъпдейт на медия
Тойота Ярис хибрид 2019г,медията ми е TAS500, версия EU 18.5.0 мога ли да я ъпдейтна до по нова версия и от къде мога да сваля ъпдейт, в официалния сайт не намерих нищо.
- TATI
- Благодарил/а: 27 пъти
Ъпдейт на медия
Не може
Ъпдейт на медия
The TAS500 is not available in the UK so info will be limited on a UK based forum, however a quick look on Techdoc suggests the latest software version is 19.6.0 this is lited on a technical service bulletin:
TSB: BE-00233T-TME Version 1 16 Apr 2020
Subject: TAS500 Display Audio-unit - Minor Bug-fixes and Software improvements
Area of Application: All Markets
Models – Model Codes: Yaris - KSP130, NHP130, NSP131
Description of the phenomenon
Below overview lists the issues that some customers may experience and report, and which have been resolved in a subsequent Software-release.
TAS500 Software release EU_19.6.0
DEFAULT PARAMETERS : Default Audio Source changed from Audio OFF to FM upon Factory reset.
DEFAULT PARAMETERS : Default Volume-level changed from 7 to 12
BLANK SCREEN : After ACC ON, head-unit stays in blank screen (rare condition)
DIAG. MENU : External Microphone fault not detected if the Microphone was not connected during start-up.
USB-PLAYBACK : USB noise heard while media getting paused or playing the next track.
USB-PLAYBACK : Using Multilaser brand USB-device doesn't work
GENERAL : Backlight EEPROM Data is written on every power cycle, causing excessive EEPROM usage.
ANDROID AUTO : Android Auto freezes when touching and holding map or scrolling through menus and at the same time another event happens outside Android Auto and the user releases finger from the screen. (Ex.g. press Home key and pop-up is triggered by pressing Volume via the Steering-wheel or Head-unit hard keys)
BLUETOOTH PAIRING : Bluetooth Device Search operation does not time-out when no device is present nearby.
TRANSLATIONS : Updated translations in Danish, Greek, Spanish, French, Norwegian, Portuguese, Swedish.
ASL : In some cases, a dip in audio can be noticed due to ASL-feature, especially at high speeds.
APPLE CARPLAY : In some cases, after selecting "YES" on the first time pop-up (iPhone X), Car Play doesn't launch correctly.
APPLE CARPLAY : On start-up, with iPhone 8 connected and Car Play active, performing a reset of the phone causes the TAS500-system to reset. After restart, Car Play and Android Auto are disabled.
The update is available via Techdoc HERE or via repair of a warranty complaint at your Toyota dealer.
