Лорде, виж това - аре да правим конкуренция на Нацистите - само 10 хилки...направо без пари
1988 Celica All Trac Rally car
Posted by: acylon
Price: 10,000
City: Troutdale
State: Oregon
Postal code: 97060
Country: usa
Phone Number: 503-780-3303
Street Legal: Yes
Cage Installed: Yes
Race Ready: No
Log Book: Yes
Car Class: Open
Description:
This is a really nice Rally All Trac. Clean title in hand. I bought this car in 1992 as a street car with about 80,000 miles and built it up for rally. It has never been rolled nor had major body damage. I have had a lot of success with this car in SCCA Club Rally, even on a small budget. It has done around 15 rallies. It has about 97,500 miles on it now, and I drove it to work for a while. Garaged all but one year during the last 14yrs. less than 1000 miles on race built engine. Car is running about 300whp in current tune at 17psi, has made 357whp with bigger cams at 17psi. Max boost engine has seen is 18psi. Comes with custom shaped removable 32mm restrictor. Fully programmable engine computer. Car weighs aprox 3050lbs wet. Best E.T. at drags 12.69 1/4mile.
For some cool pics and info on this car and my rallies:
http://www.pregrid.com/acylon/
Specifics:
Turbo: KO Racing’s Street Brawler Garrett T3T4 48trim
Hydra Nemisis aftermarket ECU
Engine, tranny & intake all ST185
JE 8.5:1CR Forged Pistons
JE total seal rings
Eagle H beam rods
HKS Stopper Metal head gasket 1mm
ARP head studs
Ferrea valve springs and retainers
1zz Cam bucket conversion
Gen 3 camshafts
Rotating assembly balanced to >1/2 gram
K&N Cone filter
Strait intake
Tvis removed
Port matched head & manifolds
HKS racing blow off valve
ST205 W/A intercooler w/ VW Passot radiator
Jabsco centri puppy 20gal/min IC pump
Unorthodox Racing underdrive pulley
Tial waste gate
Findaza lightweight flywheel
Ball and spring manual boost control
Billet fuel rail
Aeroquip Adjustable fuel pressure regulator
Walbro 255 fuel pump
3" exhaust turbo back, No muffler
3" racing catalytic converter (removable)
Billet fuel filter w/ -6AN lines
C.A.P. pressure plate with 6 puck ACT disk
880cc injectors
6 point roll cage by RRacefab
Metal Frictions brake pads (never fade, ever!)
Electric vacuum boost pump
5 Aluminum OZ Rally wheels with good rally tires
Solid mounted rear end
Posi rear end
MOMO racing seats (size: driver small, co driver medium)
MOMO adjustable seat slider for driver
MOMO steering wheel
Custom valved Bilstien inserts
Eibach coil over springs
Battery relocated to rear
Brass shift bushings
Autometer fuel, oil, and boost gauges
Westach EGT gauge
Autometer oil & water temp warning pro lite
AC removed
1988 WRC paint scheme
JIC fully adjustable strut tops
Whiteline front suspension mod
1/2inch plastic skid plate (front)
Terra Trip 303
Terra com intercom
Brake and fuel lines relocated to interior
Rear brake adjustable proportioning valve
Master electric kill switch in drivers reach
Included extras:
Light bar with 4 lights, 4 Stock valved bilstien inserts (had one rally), 3 pair of different spring rate springs, extra set of new metal friction brake pads ($300 value).
Dosen’t come with shift knob.
$10,000
Seat belts are expired.
Tags are expired, it would have passed emissions but it was to loud , 101bd instead of 95db, so it needs to have a muffler installed if you live in a DEQ clean air area.
